Small pick up type Hiab wanted
Hi Folks,
I'm on the look out for a small pick-up type crane, not a knuckle boom type.
Needs to be in decent condition...... not pulled out of a hedge type thing.
Anyone have anything about?
Look out for Hyva and Penny lift from memory..
  • Like
Reactions: CPS
Ho much are you looking to lift, I take it you have something with a bit of weight to lift on and off the truck?
Could you use a mobile engine hoist or is it more regular use planned and to be fixed to the truck
well you might have noticed an old JCB i bought in another thread? When it arrived the old man was walking around it with one of those looks on his face.... then he said, "If I cut the cab of it it might do what I'm looking" Ah feck off your cutting nothing up!
In short he is looking a small tracked crane, to work inside substations, so I suggested a small Hiab mounted on a tracked carrier...... so now he is off to cut up me JCB tracked dumper instead😫
Kobelco seems to do some great little units but seem mainly to be Australia or Japan way
7 or 8 mini cranes in Leeds euro in Jan
Grahams
Grahams
Trouble with those is the are proper cranes with the load swinging about off a wire. Having had a play on a 50 tonner I can testify it takes a lot more skill to operate one of those safely compared to a Hiab style where the load is attached to the end of the arm. Unless you need the proper crane style I wouldn't buy one.
I've recently started playing with a similar micro crane and I fully agree it's a very different kettle of fish compared to my micro Hiab.
