the Global Warming fiasco -- or how to tax the **** out of us
To be fair I've never seen mention of pure hydrogen as a replacement for nat gas but a mixture of hydrogen and ? which i guess lowers emissions and helps keep it in the pipes.
My uncle is a civil engineer for a one of the companies working on the gas network.
They have been slowly increasing the hydrogen in the mains for quite a while. Coal gas apparently had a very high hydrogen content.
They have been testing the pipework and he said the hydrogen is easier to seal than natural gas.
Although worryingly he also said that quite a bit of the London gas network is literally non existent. It is so old the pipes have completely rusted away and the gas just runs in the little clay tunnels that are left
Let's hope its leaking under a certain government building
They don't have to cut your gas or electric off if you have a smart meter they can do it from there office what companies have been doing is send an email telling you they have put you on prepaid meter and we have increased your rate to help pay what you owe .So they have switched off you gas, electric if you have no money
have read that elsewhere too .... but they can not do it if you are not indebted to them, or have made efforts to recover said debt and only after informing you of their plans and why apparently.
interestingly .... I used to be on a std 3 mthly variable DD, paid on demand and like the rest of the country, in arrears. Always paid on the nail, by the DD facility. Then they suddenly decided to alter this to a monthly fixed DD, again in arrears, as they can't charge you for what they haven't supplied you with. However, instead of allowing the usual 3 mthly to occurr and then changing, they did it a few days before that was due to be billed and paid, resulting in my outstanding bill to be anywhere between 3 and 4 mths in arrears, which i thought was a bloody odd way of going about it ........ think I might just 'catch up' that original 3 mthly and bring it up to a 1 to 30/31 day debt only ..... crafty bastards
" If the Whitby proposal is approved, pure hydrogen will flow through its pipes from 2025. Hydrogen's advantage is that unlike natural gas, it doesn't produce the climate-warming gas CO2 when burnt. "
you have now gaz
didn't say it pisses out Bri ... but it will permeate just about anything ... the molecules 'squeeze' through the gaps between the molecules of the containment materials.... the Zeppelins were a series of multiple cells, within cells (bit like bubblewrap) , which is why when you see footage of it going down in flames the flame front travels the length of it and doesn't just go off with one massive explosion
You’re still talking about very old technology managing to keep it contained for days at a time, if not longer, Gra. In that time there’s been advances, 316 stainless is virtually impermeable at normal temperatures, there are ceramic coatings that reduce it to almost zero in carbon steel, Teflon seals are used in some pipe work.
Also mixing hydrogen with natural gas doesn’t make a squat of difference to the hydrogen leaking out. It doesn’t bond to the natural gas and sits within the mix as a discrete molecule. it’s not impossible to seal hydrogen in a system, just harder, in the same way that what will seal a water pipe won’t seal some oils, or other fluids.
No, iirc it one of those “I have the right to meter my own gas supply/fight the big corporations” type situations
agreed on all counts ..... but the gas network is " very old technology " for the most part ;)
interesting .... but if they're shutting all the airports ?? :unsure::unsure:o_O
" The Department of Transport said the project will also produce 300,000 tonnes of sustainable aviation fuel a year.
The UK government said this was "enough to fly to the moon and back about 60 times" and equates to around 14,331,300 miles (23,063,991 km). "
would like to see a list of directors for all these co.s awarded from this fund and a red flagging for any MP, wives or families involved
suddenly realised they'd have no where to fly their private jets in/out of 🤬🤬🤬
you have now gaz
no ... just 6 times more CO2 than burning natural gas, in manufacturing the bloody stuff in the first place 🤬🤬 wanker emoji.jpg,s 🤬😤
just tripped over this Bob
" 'Disconnection by the backdoor'
Once a smart meter is installed, it is a much simpler process for a supplier to swap the customer into prepay mode at the push of a button, rather than having to apply for a warrant and install a physical box.
Ofgem's rules state that energy companies must speak to customers before moving them on to a prepayment meter, but the regulator said it was concerned this was not always happening.
Suppliers may put customers on prepayment meters if they struggle to keep up with bills, arguing it helps them to control how much and how often they pay for energy.
But Rosi Avis, who heads up the Manchester Branch of Citizens Advice, said remote switching is "disconnection by the backdoor".
"If customers are unaware that they are on a pre-payment meter they might not top up and therefore they are more likely to self-disconnect from their gas or electric," she explained. "
will be the last smart meter in the country if I have my way ....... and then it'll live in a lead box :censored::rolleyes:
Yep being hounded for the yard at the moment blocked their number
Needed a new meter in the refurb a couple of weeks ago. Gas man came out and started for like for like, prepayment but not smart meter. I said what is the difference, he replied you can self cut this one off if you run out of credit. If you have a smart meter they can cut you off even if you have credit!!
my attitude with 'em is .. "I've told you before - not interested, now stop bothering me on my private number - DO NOT call me again " ... haven't had a call for some time ... emails just go straight in the bin
last time I looked the roll out is at less than 12% ... sooner or later they're going to get the message :unsure:
I had a letter the other day advising me to book a time for my “essential upgrade” smart meter installation. Can’t recall the exact words now, but it was suggesting that the installation of the smart meter was to save the planet!
No but it does still give off NOX particles which I didn't realise.....
So we back to diesels? I'd love to see how much my amarok actually spews out...dof,adblu etc never seen it emit anything other than water or steam...🤣
I had a brand new gas installation earlier this year, smart meter the lot. Has never given them a reading so have to keep doing them manually. Won’t give me a date to come and sort it just tell me they’ll be in touch.
Had one at a customers last week that has been stuck on 00000.003 since it was fitted! I was there fitting a new boiler, apparently has reported it twice but heard nothing.
attitude to incompetence -- f**k 'em ...... "reported it twice" ... once would've done me
