Kubota with Tiltrotator
@Furniss Well I run a 2ft6 on my 8026 so I would say a 6t would handle a 3ft fine. These tiltrotators are hardier than you might think.
Obviously factors like zero tail, the profile of the bucket and if you are on a slope all come into play but I don't think a man such as yourself will have an issue running even a slightly oversized bucket on a machine.
Management
I run a big 3ft under my 6ton tilty all the time, cross carriage and digging below ground level it gets abit tippy but nothing too bad, just be careful and it’s all good!
direct mount ?
Management
direct mount ?
Direct onto the top hitch you can’t tell it’s on, but I only direct mount when swapping between bucket and breaker. Maybe if I was digging lots out and it wasn’t a fussy dig I’d drop the tilty off and just go straight for the top hitch - but I’ve never needed to yet!
I'm going to look at this when I'm back in uk for a few days .....what do the tilty gurus think ?
Is it a Rototilt top hitch ...build height of it and overall build height looks big 🤔
well the label on the top hitch is a bit of a give away .... does have some fairly tall cheeks, I must say
Management
Too hitches ain’t all that small, I think Aiden makes a smaller one in-house? Also steelwrist is a night tight unit, if I ever trashed my Engcon top hitch I’d be getting steelwrist and having a multi coloured tilty!
I didn't have a top hitch on that unit I hired ...it was steelwrist and was very light and compact - no gripper though.
Grahams
Grahams
I have the same unit, direct mount and no gripper (i'm to tight). Good tilt rotator and I've had no issues.
R2 is a great unit - I’ve got one (without the gripper, but they bolt on/off anyway) and I’ve not managed to break it! Looks like S40 S40 in the pics but that top hitch might be something else possibly?
I’ve got an SMP top hitch on the 6 tonner (which is amazing - very very low build height and weighs nothing) and also an Engcon in the 2.7 (which is ok but not as slimline as the SMP - better than the top hitch in the pics though).
Get it bought!
No idea, but they are only £130 a week to hire at jewsons so I never replaced mine!
But they only hire you the ones that have got the horn for every time you go forwards!
And I'm with you Dave, I think Steelwrist make some of the nicest compact top hitches I've seen. My Engcon ones are also nice and compact but they are made specially for my machines I believe. Once you get to S40, Engcon seem to go to a generic hitch with spacers to suit your machine and I always think they look far too bulky. And if you have a smaller machine in the hitch size it looks far too big, not so bad at the other end of the scale. Is your 57c on S40 or S45?
Management
S40 , generic Engcon hitch, doesn’t look out of place on my setup to be fair. only issues with it is it seizes up as it’s not used a lot, needs someone else to give it a belt with a hammer when your trying to take it off after a long period of no operation, which is every time pretty much!! S40 btw, s45 is huge by comparison, deffo more suited for the 8/10 ton range!
