Running an ESAB mig as well at work. Never tried it on anything heavier than 1.00 mm wire. It came with a spool of ESAB wire, think it was nickel coated ER70 and it would not run it, back on the copper coated and again, runs a treat. Gun gave out at low hours but we’ve now got a Parweld torch and that’s improved things no end - not least cheaper consumables.
was it coated or just bright wire Bri .... used to use the copper free on the boats, as it'd never be on the sets for long enough, to go scabby, otherwise was always CCMS, but if it wasn't going to be used for a few days, they came off and stuck in the heated office, or it'd be powdery
.... the bright certainly saved on liner issues / regular cleaning/replacement, not that they were dear, just a faff and half hour downtime
usually Binzel copies ... which're good all rounders ....
had a big Tweco for occasional use with big wire and a Bernard which was also a good HD torch, but both were a handful .....
MB32,s - 320A Binzels were a nice compromise for general, everyday use with 1.00/1.2mm wire and the MB25,s, nice for lighter duty bench work on 0.8mm ... had one little MB15 for really fiddly/light stuff, but rarely got mounted .. all 5M leads ... 4 was just too short
