interesting looking device
one of those youtube annoying interruption adverts .. video looked quite cool though (y)
@Monkeybusiness pull this out on your next job for the craic 🤣
C
charlie2
use an old oregon filing guide clamps onto bar does not take long to set and file chains and works well enough got a cheap electric lidl one thats ok if i have really blunted a chain but still finish with the guide. when i first started work in 1970 at an agri engineers chain sharpening was a task that got set to me using the same type of guide i still use.
I actually found a Dremel one ...frig it's lethal not accurate and one slip and it's swear words ..
Have got cheapo disc type for buggered stuff but can't beat file
You can. A properly set up disc type, a CBN wheel and a mist coolant system.
Not cheap at around £550 for the lot.
When was the last time you sharped your own chain anyway? 🤔
I sharpen mine on a bench grinder and give the chain a dressing every tank with a file. I keep five chains on the go - cycle through them and then do them all at once on the bench.
I've got a diamond wheel I'm yet to try for the carbide chain.
I've just bought a 4st pole saw running a 3/8lp chain. Haven't decided how how I'll deal with that.
Those little chains are dead easy to sharpen with a 4mm file, and tend to stay sharp as you aren’t cutting near the ground with them.
