Old rubber tracks!
Just putting it out there at this stage although still on machine. I say old. There in superb condition don't think there's any cuts on them, bit of wear perhaps 70% remaining. Would suit cx75, Kubota 080, and quite a lot of others I think. Wanting to replace with steel. Would they be any interest to anyone. A new track is £1300 Inc vat so not sure what these are worth to be honest....
Thomas7740
Thomas7740
Have you had any prices for steel?
Well I got £100 for a shagged old one off my 3tonner (only £400 new at the time) so a pair in good condition I'd say you would easily get 50% of new price? A demolition firm bought mine, they like old tracks as are constantly tearing them so there is a market.
£2800 plus vat from MST for 600mm steels - that's both tracks. Think Evan and Reid was £1100 per track plus vat for 450mm. Not too terrible. Will probably go for the wider MST ones I think. They said it should be a direct swap. No need to change any other parts apparently 👍
Change the sprockets too, otherwise you are potentially accelerating wear on your new chains.
Sprockets have very little wear but seeing as they're not major money I'll probably sell them with the rubber tracks
The problem is they may look good, but if the pitch of them is out, even but a small amount, they will immediately start to wear your new chains in an effort to match their pitch. As you say, for the price of them I think it’s worth it.
I had this issue going from steel to rubber....it wasnt happy on the old sprockets with the new tracks and would spit them off so put new sprockets on too and since no issues.
Well if any one wants a pair of second hand tracks. Probably offer them for £750 for the pair. Think that's about a 3rd of new price so might be worth it to someone👍
Thomas7740
Thomas7740
I was quoted £2750 plus vat for 700mm steels and a pair of sprockets from Johnston Heath LTD. They recommended the 700s over 600s.
That's a good price. Wonder if they deliver to Devon. Why did they recommend the 700 over 600s- other than the obvious flotation benefits? My only worry about going that wide is the increased potential for damage against rocks and stumps, also I did think that anything wider than 450mm is going to be wider than the blade which might not be a problem in practise. Could always get a decent fabricator to make up some extensions to weld on to the blade.
Thomas7740
Thomas7740
I queried why they recommended the 700s, I thought they would be harder on track motors than 600s, they said it’s the other way about, more float less drag with a 700, so easier on machine then. Dunno if it’s right or not but that’s what they told me
does make a modicum of sense ... lighter it is on its feet, the less stress on the motors and rides higher in the field
Except when turning perhaps. Skid steering a 700 to the side would have more friction than a standard 450mm?
agreed, but would not be as 'deep' into the surface its running over (if soft) - deffo on a hard surface .... this can also be alleviated by how you turn/make the manoeuvre
I shouldn't think it would make a huge amount of difference. As long as the depth of the tracks doesn't change. Or it will be like road blocks where they just sink in and work turn as they are essentially sat in a trench
Track width is all about ground..... Mine do alot on hard ground and when it's soft it's bog mat territory. Narrow tracks grip better and reduce chain wear when on uneven ground.
Wide tracks will accelerate chain wear if the ground is uneven or stoney.
Horses and courses..... Personally wide pads are a expensive status symbol in alot of cases
I'd agree it's surprising how wet you can take a machine on even standard tracks. I think 700 would be too wide for me but 600 would be nice on peatier parts of the moor I work on. One of those things 450mm is fine for 80% of jobs but the extra width might allow for a job to be completed easier and less mess for the other 20%. I quite like the carpet finish that wide tracks leave behind them.
