MPG for an 18t lorry
Justme
I am sure someone in here will know.
Finding it hard to get any specs for an Iveco 180e25 from 2008.
Roughly what sort of mpg can I expect empty and with a light load of around 3t (plus the hiab)?
Will look at down plating once the build is complete to reduce RFL & insurance rather than looking at maxing out a 10-12 tonner.
Left hooker
Left hooker
Wouldn't down plating reduce axle weights so make it rubbish for hiab as front axle would be over weight
Can leave axles wrights as is I think. Some of the Renault 8 wheelers have axle weights combining to 55tonnes.
And if mpg is important wouldn't the smallest chassis available be better. Smaller lighter chassis also smaller lighter cab so better aero dynamics.
If you want extra capacity 14-16t will still run a smaller cab and smaller components.
Obviously hiab size depends but an Isuzu 11t with 8tm crane should still be running around 5t unladen
1RB
1RB
Daf 14 tonner 220hp loaded getting 10.8 mpg.
I used to drive a foden 4525 double drive for my dad with a 14 litre cat in & moving crane weights from ainscoughs in hays to london at 150 ton gross it used to use gallons per mile 😢
Prob empty 1/2 the time ...small roads ...manual box ...Michelin tyres - 8t empty - 19t max
Perhaps my memory doesn’t serve me as well as I thought!! I did rather plod around!! And it didn’t have any of this modern euro emissions crap on it!!
Big Jordy
Big Jordy
Drive an iveco 180e25 tipper it’s 9.4 ton empty and it’s a sore
Bast**d on fuel if yours has hiab I’d say nearer or over 10 ton.. 6 Speed box will likly miss in 2nd and be a bit*h to get into reverse and the comfort is non existent…
Hope this helps
Hope this helps
Haha exactly the same experience I've had.
Also the heating is completely hit and miss. And best of all keep fit windows.
Big Jordy
Big Jordy
Yea lol they are interesting the driver door opens when you go over a good bump by that I mean a gulley cover on a road lol and ours has recently been giving a lot of electrical bother and coolant problems and air problems.. but all in all a good bus lol haha 😂
