Distinctive duck with rotating dipper
Bucket on wheels
Bucket on wheels
Where the translation says ( the sewers ) it should be. melting skips
https://translate.google.no/transla...r/saeregen-graver-med-roterende-stikke/464709
It kind of surprises me that none if the tilty manufacturers make a replacement Dipper like this it kind of seems like the next step for the people that want to reduce the build height
Would still give you a large range of movement even without a tilt hitch at the bottom of a rotating dipper
bit of a waste of a duck IMHDO .... the ladle is on a manipulator/rotator ... could have a fixed arm set up like in a quarry crusher and a booth to operate it from
There are people making similar attachments like this to fit telehandler and skid steer type machines.
Reminds me of a robot arm setup. 6 axis.
K
Komatsu
It’s been an option with Komatsu for as long as I can remember
  • Like
Reactions: LDK
I bet that would make your ears ring!!!
