Grease gun heads
I’m having trouble finding decent grease gun heads for my guns . Anyone had this issue and found better quality ones ?
Three jaw alemite chucks are spot on. Never used the safelock type but then again using the alemite I've never had a problem unless the nipple is mullered and needs replacing
tried the ubiquitous G couplers Vin??
I tried one of the Ying tong ones out of curiosity too ..
the genuine G,s have 4 gripper jaws .. the ying tong only have 3 and TBH I've found them a stronger, better gripper than the 'real' ones
Got one genuine G that now leaks .. cheapos're still going strong :rolleyes::unsure:o_O
there's also these, but no idea what they're like ...
this also looks a handy thing
Nowt wrong with g couplers apart from the price as long as they fit, won't fit on some recessed nips. The only g coupler I've had bother with just needed a good clean out. I always have grease guns in pairs one with g and one with takis own end (which I've never bothered to find out where to get them)
Nowt wrong with g couplers apart from the price as long as they fit, won't fit on some recessed nips. The only g coupler I've had bother with just needed a good clean out. I always have grease guns in pairs one with g and one with takis own end (which I've never bothered to find out where to get them) View attachment 39404
When I got my Taki grease gun same as yours I thought it would be absolutely useless. But actually find it surprisingly effective and I rarely get air locks in it either.
I've a few Alemite guns, but put G,s on 'em from day one, so no idea what the Alemite couplings're like?
The alemite couplings are far better than other standard one. Like anything they wear out and need changing but my one will grease stuff that other things won't touch and I can stand on the handle when trying to grease blocked fittings. Whereas alot I have used will leak with that much pressure applied.
L
Lynchy
Better to change the fitting?Bloke got 'shot' in the leg when ball came out of over pressured fitting few years back,local to where I lived then,turned septic wasn't good for him
