Had afew of the forum favourites working on jobs for me the last few days,
@Monkeybusiness sorted out some dangerous trees for us
Then @Mogman lifted me a pair of ridge beams into position.. BANG TIDY
Hoping to put a new set of chains and 700mm pads on in the new year, not a fan of these
700mm? Didn't know they could fit on them. MST priced me some 600mm steels to replace the rubbers on my cx75. Interesting to note it's a straight swap from rubber to steel apparently.
The only thing about fitting wider than standard tracks is the blade is then narrower than the tracks
Thomas7740
Thomas7740
Can fit 900mm without any mods, slight mod to allow 1m tracks, according to dealer. 600mm and 700mm pads where the same money, they recommended the 700s, apparently there is less drag with with when turning
L
Lynchy
Getting ready for Saturday night,both ended up q/h off,21 years of no closer than 2.75m to ole unless isolation,c form,simple as that!
Funny weather today monumental rain then hot sun then rain, started screening the spoil pile with the new Lloyd screener, soiled up the splay, talked them into a name stone in the wall one of the ones we dug up. Then sprouted a stream from blocked gulley in road.
Apache did a flyover
Screener looks good
