A
Agrimax
Hello folks,Just joined up and rather than faff about get nowhere I thought I'd ask here. Am well used with working at tractors and rubber tyred diggers but not so much with 360s.
The above machine has decided to track on one side while slewing or working the bucket ram and that's without touching the track lever. Both track levers are sticky and don't return to centre on their own,although the springs seem to be fine. So that needs sorted! When the track turns with other functions being operated,if I stop everything and then work the track lever on it's own,the track will not move. The lever has to be pushed and pulled a number of times to regain track movement. Hope you can follow. Anyone know what the problem could be? I'm thinking maybe the seals in the rotary coupling underneath perhaps?
