Sheeting of loads trailers and transits
Looking to clarify before the situation arises
I run rd with my ifor tipper trailer on with mainly caged sides on, I’ll sometimes put stihl saws and shovels loose on there with say 1 ton dumper.
If I’ve got the cages on do I then still need a net over top or my big cover on.
Understand with mesh sides off and loose load ie sand it’d need a sheet and with mesh sides off and rakes etc they’d need netting.
Trying to decide if I need a net and tarp or just tarp sheet
I’m big fitter cover is a ball ache to get on on your own and when left on end up with two huge ponds of water that if I don’t tip it and drain them would rip the cover.
Mudfords do a net, around £20, its what I've got on my little truck an use it on the grab lorry too. I've put some big bungee cords on it and you can always get it nice and tight with them
I think Rory summed it up nicely in the fact that if you point out your case then they should back down on their silly rules!
Can't you just carry a couple of bungie straps?? I always try to as I get fed up of the noise of shovels sliding up and down when there is nothing else on.
Also my colleagues have a tendency of snapping the black sticky out bit of Stihl saws by letting them slide around on there side leaving no dust suppression
If the load is lower than 6" from the top and unlikely to blow out I'd not be worried
They are really clamping down on anything without a net/cover on it, going wayyyy over the top.
Showed up a grab lorry with a neigh on level load of breeze blocks, loaded very tidy and safe imo, they shafted the fella! More chance of the bloody wing mirror falling off!
So the loadbearing curtain whatsits on curtain sider...you need a full load from head to tail to be legit and not need straps obvs..firm we use lad said their night trunk was 1 pallet down...screwed him royally as that means the other 31 euros should have individual ratchets not even fly overs as they over 300kg or whatever it is. Jobswirths.
They really hate the XL curtains. They are utterly pointless unless carry very light wood chip as the ministry simly find any reason to consider them not good enough on palletised goods. And heavy chip puts enough of a bulge in the curtain to put you over width. Yet they cannot fathom why noone wants to drive a lorry.
The ever moving goalposts are already outside the stadium
Don't worry Rorys mate rishi is going to rip the rule book up 😭😭🤣🤣🤷
Rishi ain’t getting a sniffy at the rule book!!
The discussions over hours, diary’s and load restraint would be funny if it wasn’t serious!!
You do have to question why the rules are so complicated. Easier to catch someone for a motoring offence that catch a real criminal!!
I have 10 or more on ladder rack
It’s more DEWALT boxes or boxes of mdpe water fittings etc shovels generally go in truck
Ifor do do divider for the tippers as well
Link? Or they local?
