Fuel filtration polishing rig
F
fueldoc
Each case would have to be judged individually it all depends on the base fuel and how bad it is. for polishing its normal to pass it to and fro until it comes up clear and bright.
Yes of course its the same unit as on eBay and Facebook market place and other places, why would it not be?
No reason - my mistake.
Reading your first post, I assumed it was a 'proof of concept' build, not a 'ready for market' build.
As I said, "it looks like something thrown together on your afternoon off."
I’ve got a few transfer and polishing rigs in the shed, some bought and some built by us. In all fairness , no one is going to get rich selling this for £750. My cheapest transfer/filtration rig cost double that to build and the IPU one I have is somewhere between 5-10K now I think.
The pump is a shitty Chinese thing and the hoses are crap and meter inaccurate. The genuine Raaco? Filters are dear and these are imitation ones but probably work okay.
All in all.. it’s about right for the money.
interestingly the two pix posted have differences in their front/rear views or is there a balance tube front and back ? ... trolley looks to have the same scuff on it though
what no one has thus far mentioned is that Galv fittings're a no no for this sort of set up ... black malleable or brass
What is the problem with gal and fuel? It sounds familier, but can't remember the problem.
Personally I like brass, but I buy stainless cheaper.
F
fueldoc
The issue is that Zinc from galvanising might transfer into the fuel, I agree with that, but in such short lengths of pipe I do not think it will be a problem however if some body wants black iron, better quality fuel hoses or any detail requirement like filter gauges sampling points everything is possible. I know I could have used different quality components but I am aiming this at a middle ground occasional use not necessarily at folks who would use it everyday.
Zinc and copper (from brass) can poison aftertreatment systems. That’s why they Recommend synthetic oil, some of the Older mineral oils could promote copper being transferred from oil coolers, main and big end bearings in minute quantities, but enough to cause an expense.
Hmm ... I spent some time down this rabbit hole and learnt a bunch of stuff I didn't know, so thanks for the prompt.
Leaching copper from brass wasn't expected and the range of effects is bizarre. Ignoring the aftertreatment problems, trace amounts of copper in diesel improves combustion, reduces soot and improves "ignition probability".
The common jet fuel is A1, the naval equivalent is JP-5. The US navy considers copper leaching from refueling lines on their aircraft carriers cost them $1billion in degraded performance each year of their JP-5 fueled aircraft.
So much for brass being ideal!
We use 100% stainless steel fittings on fuel lines in test machine installs, and on supply lines to the test beds. No brass, galvanised or plated, and only certain types of rubber and plastic.
