Jcb 801.4 manual
G
GeorgeTRV
Hi Guys.
Recently, I've bought a JCB 801.4, 2001 I think, the plate on the front is missing.
The plate on the engine shows "Perkins 2008".
I managed to download the manual for the engine but I struggle to get the manual for the JCB itself.
Can someone help me up to send me a service manual?
TIA
Hi Guys.
TIA
welcome to the forum George ... not got a manual sadly .. some one may have though
Rob65
George,
I have PM'ed you a manual which I think will help you out.
Rob
G
GeorgeTRV
Thanks for your help guys.
BTW, how shall I do the hydro fluid change?
Remove a hose and use the joystick to get out all the fluid?
Does it have a screw to remove the fluid?
I couldn't find the instructions in the manual.
should be a tank drain plug
DO NOT run your pumps dry under any circumstances
I've a 2002 8015 ... will see if I can spot the drain and take some pix for you
Rob65
There is a pipe that runs from the hydraulic tank to the hydraulic pump.
If you disconnect this from the pump all the hydraulic oil will run out of the tank and onto / into whatever is below!!!
Don’t ask how I know this 😀😀😀
like the monkey trying to get the cork back in ???? :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
I think if that's the best option for draining it then sucking it out would be more fun
Generally considering how tight it is in minidigger engine bays one of these is generally a very useful bit of kit to have
KATSU Tools 481509 Manual Fluid Extractor Pump - 9 Liters https://amzn.eu/d/4dd6tq1
Also very useful if you put the wrong fuel in something or a tank gets water contamination
deffo (y)
I use Aims tools for Katsu stuff .. much cheaper
