So if it’s below the sides you don’t need a net? Because realistically is a roller over net going to stop piled high 6ft on a rough road anyway?!
Nets are only suitable for preventing dust blowing off a bulk load. If transporting oversized (say 75mm clean) that cannot produce dust you don't need a net.So if it’s below the sides you don’t need a net? Because realistically is a roller over net going to stop piled high 6ft on a rough road anyway?!
Literally every police force I follow are all now stating every load regardless of what it is should now be coverd/netted?!Nets are only suitable for preventing dust blowing off a bulk load. If transporting oversized (say 75mm clean) that cannot produce dust you don't need a net.
Yes, because no one is standing up to them.Literally every police force I follow are all now stating every load regardless of what it is should now be coverd/netted?!
If he was actually overloaded he got away very lightly only having ”words of advice”.
Yeah no numberplate tut tut but everything else is pathetic!
Bm lorry driver today said they've been told to net everything. He had 4.8m timber left on strapped down but had to net it.Literally every police force I follow are all now stating every load regardless of what it is should now be coverd/netted?!
No address to send the paperwork toThese clowns want to go after these transit people that have steel piled high over weight etc.
But they won't because it will cost to much money to do so!
Yep so easy take the vehicle off the roadNo address to send the paperwork to, if your legit, they`ve got your details before they even speak to you.
must be a bloody fine mesh ... what Denier is required to capture dust ?Nets are only suitable for preventing dust blowing off a bulk load. If transporting oversized (say 75mm clean) that cannot produce dust you don't need a net.
www.tillypass.co.uk
I'd bet my left nut that if they'd had a pad weigher and set the draw bar down on it, it'd have been way over the prescribed limitThe “law enforcer” confirmed lower down that it was a ‘over height’ overload.. ie above the sideboards…![]()
Probably.. but so too would every trailer behind a car/pickup! 90kg nose weight for 3500kg isn’t it?I'd bet my left nut that if they'd had a pad weigher and set the draw bar down on it, it'd have been way over the prescribed limit
Depends on which is the lowest rated, the vehicle manufacturer, the coupling, or the drawbar. Usually the vehicle manufacturer is the lowest.Probably.. but so too would every trailer behind a car/pickup! 90kg nose weight for 3500kg isn’t it?
I've got to be honest the entire Tillypass thing boils my s**t.Apparently these guys have written an article on it.., shame the website is so poor it doesn’t load the blog up!
Covering goods while transporting by agricultural trailer.
🚜🌾COVERING GOODS Agri trailer towing. Regulation 100 section 2 of the Road Vehicles [Construction and Use] Regulations 1986. There have been a number of amendments since 1986 but none of them pertain to regulation 100 so it remains in force and it states:(2) The load carried by a motor vehicle...www.tillypass.co.uk
