Manitou man basket
Well I’ve sold my big manitou but kept the fold out man basket to go on it’s replacement but things have changed a bit🤔 so now it’s up for sale, it opens out to 16’ and pivots 90 degrees left and right from the central position so can drive down the side of a building and the full platform will be side on to the building
will just work from the auxiliary hydraulics on the machine looking for £2,500
Reminds me I must pay you 🤣
@Giles wanted this didn’t he?
I got just the job for that too ......... but can't justify the £2.5k ....... to myself :cry:
could access most of the pine end of our barn with that, if not all of it, (with a little tweak here and there) ...... and it needs accessing soon .... bloody long way up from the small floor area under it and damned difficult to get at from anywhere else.
will it swivel both ways @Mogman ? (looking at the bump stops, looks to come around one way more than 90 deg.s - sadly the wrong way - for me at least !) and any idea what it weighs?
nice looking fuel tank beside it ;):giggle:
There not bump stops that’s where you put the pipe fittings when not in use😉
and it does rotate both ways 90 degrees 👍
Ruggsta
Is it still for sale.? Desperately trying to find one for a hydraulic man basket for our Telehandler.
Pedrod355
Pedrod355
Be good if you could change basket for a fly jib on end of swivel coupling for putting trusses on
Ruggsta
We are trying to fabricate a plate that would allow us to switch from the basket to the jib. We think it would be a good idea as well. I just need the head stock…………
Pedrod355
Pedrod355
Is the swivel a manitou part or aftermarket as said before keen to see if possible to adapt similar to adopt a flyjib on end
We've got one for our JCB loadall, it goes from Q-fit to Q-fit so anything you can put on front of loadall you can put on swing jib. Forks, jib, man basket, fly jib. Handy for tight access places or if you can't get square on to building with wide basket on, can just pivot round square on. Ask @CPS to build you one 😉
Could you send me some pictures @Quattromike please?
It's quite big/long to suit JCB Q-fit as it swings 90deg both ways so if you have a wide basket on it clears the machine carriage. Manitou ones can be smaller/narrower. But the length helps with a fly jib on as it give more reach. One to watch out is when using a fly jib you need to keep it fairly level as if you are crowded back you are relying on the small pivoting rams to hold position against gravity wherein keeping level take all the strain off and all they have to do is swing it round.
