Pedrod355
Pedrod355
Be easier just making a solid section from 400mm to nowt to bolt to the bottom of the door than cutting the door off at an angle through the slats I'd have thought and doesn't spoil the door itself.
Out of what?
Diggerdavey
I've seen it where the bottom of the shutter has been removed, the shutter slats cut to fit the angle and the bottom bit reattached. Obvously will hang down a bit on the lower side when open, but the actual access height will be the same all the way across.
Yes I’ve seen them done that way too. Although 400mm hanging down in the doorway one side when the door is up could cause havoc
L
Lynchy
Pump firm reckons it's a along bit over 30t a day out
Built some raised veg plots at home, fenced it off, will be putting some rabbit netting around the whole lot to keep the peskeys out!
Thomas7740
Thomas7740
Digging out and levelling ready to dig garage founds. First day out with the 80. Happy enough with it, stable, powerful and smooth along with good reach, just not the fastest on the planet.
Mostly stoned up and ready for marking out. Quarry is bloody slow getting stone out atm, few drivers off with Covid has held it all up. Cat is off hired so just sitting there. Got roller in today to compact it all, really not a fan of this one.
Then home for a quick chat with the boss before getting farm work done
