Russell
I wonder if that was pre side bars?
doesn't look like it ever had anyOdd to chop side bars off ...they are handy to keep you on board...
Mebbe actuallydoesn't look like it ever had any![]()
doing worse than it did the first time aroundThe ranger looks ok
think that's the second time they've had it up .. ob.s didn't make reserve last timeworth call to ask 'em what it's gotta make if you were interested
I wouldn't touch another Ranger personally, just had my 2008 trailered away to the export scrappers, 117k miles, engine solid, gearbox, 4wd all working fantastic but chassis rotten from bumper to bumper...I consider that "built in obsolescence". To be fair it's probably how most trucks are made nowadays!doing worse than it did the first time around
2017 Ford Ranger Wilktrak 3.2 Manual, Odometer 42,697, VRM FP67TLN Date of 1st Registration in the
www.gavelauctionsonline.com
That was the transit tipper problem apparentlyI wouldn't touch another Ranger personally, just had my 2008 trailered away to the export scrappers, 117k miles, engine solid, gearbox, 4wd all working fantastic but chassis rotten from bumper to bumper...I consider that "built in obsolescence". To be fair it's probably how most trucks are made nowadays!
At least you can galv a Defender chassis, then they end up outliving you, the chassis, not the rest of itI don't think you can blame the chassis rotting out on built in obsolescence. Landrovers chassis have been rotting out prematurely for near 70 years
And the 08 plate rangers are good ones built in Thailand by Mazda.
The new Ford built ones don't hold a patch to them
Used to use those when doing footpaths around council houses![]()
JCB HTD10 TRACKED DUMPER HIGH TIP 750KG HONDA ELECTRIC START | eBay
13hp electric start honda engine which runs spot on. This has been a very handy and useful tool over the past 5 years We have used it for moving hay are horse manure around the yard aswell as stone and other materials we have also used the arm on the front for clearing paths and cleaning...www.ebay.co.uk
Looks like it could be a bargain. Never see much about the JCB htd10.. I wonder why they don't make them anymore?
Were they any good?Used to use those when doing footpaths around council houses
Yes surprisingly the loader was very handy just don't flick it fast otherwise you end up with material on you when there's not much on the shovelWere they any good?
Alot better than the newer ones.Were they any good?
Yes, they are rebadged Hinowa.Were they any good?
Sort of. The idea is generators are more efficient run under load, so any spare power is syphoned off into the batteries then the diesel engine shuts down and you draw down the battery power, then repeat.Home Page | Thimbleby & Shorland
Thimbleby & Shorland, Chartered Surveyors, Auctioneers,Valuers and Estate Agents has been in business in Reading, Berkshire since 1901.bid.tsauction.co.uk
is this a battery back up ?
bet that does the batteries a power of good - NOT !!Sort of. The idea is generators are more efficient run under load, so any spare power is syphoned off into the batteries then the diesel engine shuts down and you draw down the battery power, then repeat.
Hitachi used to have a range of themNever seen one of these before![]()
