Aluminium diesel tank 400l FS
O
oldchips
Here is an aluminium diesel tank, 400l.
Bought to use as a backup supply, but the hassle factor in getting it filled is just too much, poor access into the back garden!
It was bought a little while ago, apparently came off a containerised generator and was bolted into the wall of the container, hence the shape.
In near new condition, now empty but was filled to the brim when I bought it, drained by the seller! Not bunded.
Weight 72kg empty.
Price £350 collected from near Grantham.
you got any dimensions for that old chap ??:unsure: looks typically 'military':rolleyes: ..... completely OTT :giggle::giggle:
are the top pipes dip tube type pick ups/returns ?
can't believe they've seam welded that to the back plate :eek:
O
oldchips
The tank is about 60" wide, 32" high and 13" deep excluding the various filling etc pipes. They will add a good few inches to the size.
Oh yes, military, no idea exactly what off but looks unused, but many years old. Label talks in litres and kg, so UK not US.
Fill connection, a small vent and a couple of feed and returns, I assume. There is a drain tap at the bottom.
It looks like the actual tank is separate to the large back plate, lots of welds, doubt if it would be possible or sensible to actually separate them, just cut the tank off.
Hmm .... not ali wool filled is it ?? or baffled even ? certainly is a splendid specimen of a tank :)
O
oldchips
All looks bright and shiny inside, can't see much coz of the baffles.
O
oldchips
Alright, in the way and got to go, price dropped to £200 which is a little more than scrap value.
