Maxus
I went to use it on Friday it fired up but instantly died, had no fuel in the tank. Refuelled and would not start! As I write this I realise I should try fresh fuel, but pretty sure the fuel I have in the can is reasonably fresh.
Replaced old spark plug, it's definitely producing a spark. Replaced air filters. Took out carb and gave it a clean. Fuel is getting through, as plug is wet and fuel leaking out exhaust! Has good compression.
Before I take it to a machine repair place is there any other things I can try? Perhaps one of you guys has had a similar issue?
