Yard tidy up
Geith hydraulic thumb off 5 ton Kubota, I bought this off polish built former member off the old forum,
Thumb arm, long 40mm pin to go with quick hitch. Ram. Can include the taps but handles missing off them so use a spanner to switch them. Not got the steady bracket as welded to arm but easy enough to make one or have one made.
I gave Paul £1500 for it 4 years ago off his u55 when he put an engcon on it not sure what it’s worth but It’s been sat in yard for a year or more since I bought selector grab off @CPS Aiden.
£1000? Located Peak District
Geith tilt grader for 1.5 ton currently set up for kx016-4 so 30mm pins I’m gonna say 90mm shoulders and 130 centres but will measure and confirm. I bought it new off Callum at highland hammer hire. Reversible cutting edge hardly had any use as have one for 3 and 5 ton not used it for few years.
800mm wide
Geith at02-800
£500
Some other stuff need to get rid off, 5 finger grab bought blind in an small insolvency auction with a js130 assumed it was off that but it’s on 80mm 20 tonner pins, set of Strickland forks 80mm pins, jcb 100q breaker came with other breaker I bought for 5 ton, jcb breaker owes me £600 30mm pins but knock in 25mm shins
Any ideas for this I’ve no time and it’s at yard so no time to tinker at night with 10 week old new daughter so getting shot of this. Unless anyone point me at a good generator repair guy?
Stephill 10kva generator, bought of a guy local who had it as a off grid power supply for his workshop he’d got mains, bought not working as project but I’ve not had time to invest in it.
Starts first time runs perfectly beautiful little low hours 3cyl Kubota engine.
When I bought it it’d start then report no rpm then stop do this 3 times then shut off.
I changed the computer on it (£100) that didn’t help, changed the big capacitor £50 that didn’t help, I’ve run out of time and idea so it’s going to someone with more time or someone who wants a cheap low houred engine for Kubota mini digger or tractor,
I let the battery drain down, jump started it abs it worked perfect rpm power on 110v and 240v then built it up it ran charged the battery then stoppped producing power or reporting rpm
Got a video of it running but can’t seem to post it here
Bobcat 753 with sweeper, forks sheeps foot compactor, lifting beam, over tyre tracks, bucket, towable. Early 90s hood strong little machine have moved 1000kg with it.
Has sat for a while just done wheel motor seal and taken rear rams off. Simplified electrics would suit farmers etc
£6k for bobcat and £1k sweeper, £1k sheeps foot, forks 500 lifting beam 500 tracks 800 or all for £8500 or offers.
Be a beast on farm etc
Got so much stuff taking space in yard it’s got silly having been so busy, not started on hand tools power tools yet haha
Let it get a bit crazy where I buy stuff but never sell anything
How well does the roller work? What does it weigh, is there a plate on it?
It’s about a ton, old ramax trench roller got bobcat plate on it. Worked brilliant on a 1m fill behind concrete Lego block filled with clay and packed it down in layers great end result vs tracking in. Tempted to fit to 5 ton on arm.
maz
maz
Got an idea of how much your after? I need one and the father in laws a sparky 😏
go well on a dipper too, I'd've thought :unsure:
oops forgot to post this earlier
I am still thinking about adapting the roller for my 8 tonner. Apparently I posted on the wrong thread an amazing request. Would @Giles be interested in sending me a PM with best price that might just tempt me!!
