i could quite literally kiss you !Hope this helps, look's like the very last bit is takeuchi dependent, the rated speeds are different though.
veryHope this helps, look's like the very last bit is takeuchi dependent, the rated speeds are different though.
That's exactly what I took away from it. not knowing the machines it was equipped in I didn't get the 1r bit, but logically it makes sense, I wonder if the B is for excavator application.3 cylinder
block code tnv
with a 70mm bore
rated speed 2400rpm
T not sure ? poss max of 3400rpm?
then B1R is takeuchi number ?
