Wanted . Excavator forks on 50mm pins
I’m after a set of forks on 50mm pins . If anyone’s got a used set that’ll be preferable if not a recommended new set . It’ll be occasional use so cheaper the better . I’d prefer fixed type but sliding bar would be ok as well
buy a set that suits and get some 50mm bosses welded (and I mean WELDED!) to the tops of 'em .... think some one put a set on here last night/night before?? .... should get a decent enough set for 100-ish quid
Matt's the boy to sort pick ups out ... done a great job for me on a purchase a while back @Vinpetrol
these are 20" carriage, so're gonna be 3 tonners min. at a guess and the lugs come off easy enough with a thin disc through the welds (always handy to keep too ;))
I’d agree but not desperate for them & a set should last me a lifetime so 2nd hand in decent nick would be preferable, just keeping an eye out. Seems plenty of 45, 65 & 80mms about.
I think a lot of the earlier 6-8 tonners were on 45mm pins but for some reason are now on 50mm pins this must be why there’s quite a few 45mm about.
Management
I once had a miller scoop bucket on 50mm pins i couldn’t find anything to fit it so ended up pretty much giving it away! Rare size once upon a time!
Moderattor🐾
Thing is the 7t class has grown upwards in tonnage from the likes of the EX60/70 at a Modest 7t, to the likes of a Hitachi I know of which is 8.5 (Actually 11t with all the s**t that's been added)
R.e 45mm pins, just buy a 45mm set and either grab them in the hitch or make some 2.5mm thickness pipe bushings to make it up to 50mm.
Fyi I run a 45mm set on my 50mm hitch with no issues.
A few options on facebook marketplace
my 50mm Hill hitch under my VA-r happily picks up 45mm and holds Jake buckets well .... grading bucket I had off Mick with it has a 50mm and a 45mm pin front/back ... picks on the 50 and clamps on the 45
I did wonder if the 50mm pick up hitch range would cope with 45mm
