very cheap DS&G
anyone fancy a Rolls Royce for Fiesta money ... this is cheap .... obviously didn't sell in a recent sale ... looked at it on their site IIRC last week
@CPS
jd6820
jd6820
@CPS
Looks like they are sold, was gonna have a go at the DSG. It would have been a handy size to complement the 21" DSG I bought the other month. Haven't uploaded pics yet as I'm embarrassed that its currently sat on blocks next to a pen of cattle! 😅 Soon to be relocated to the workshop when that gets sorted.
lovely machines to use ... don't often see a turret version
What’s a good make of single phase lathe?
:oops: ...... if you want a nice lathe (I presume s/hand), buy a 'known' breed and change the motor ... or buy a VFD ...... what sort of size are you talking Bri?
20” bed, bench-top preferably. Mainly for pins Up to 2” diameter. What are Unimat or Millbro like?
TBH Bri I have no idea on those ... I see a lot of training schools using Warco stuff, which presumably have 'come on' a long way from when they (Warco) first appeared on the market .... always had bearing issues back then.
lose the bench and get a nice Colchester Bantam ... see plenty about at circa a grand lately and were a very nice 'small' lathe, built to last forever, by known manufacturers with 'a history'
or for a bit bigger budget
the transwave inverter with this one is worth half the asking price
jd6820
jd6820
Nah this isn't a turret version either, need to find a 4 jaw chuck as I regularly machine awkward parts and rarely use a 3 jaw. I'm amazed at all the attachments it came with too. Both fixed and travelling steadies, drill bit holder that mounts to the saddle and can be driven into the workpiece. Boring bar holders and a DSG quick change tool post with numerous holders. Flippin thing is heavy though! Took 16 tonner and 3.6 ton lift loadall to get it off the wagon.
Seem to be built to work, the saddle has a built in oil pump fed of the lead screw that lubricates the ways. I've never seen that before? Just need to find a more handy tool room lathe for the lighter work as its spindle maxes out at 1200rpm which is pretty impressive for the size of it. Fair old surface feet per minute passing the tool. :oops:
love to go for something like one of these, but space precludes… Got to be able to move it with the K008!
yeh those 21,s're a hell of a lump ..... my 17-36 was a hell of a weight for what it was, but they're superb weapons ... the 17,s were purpose built toolroom lathes .... but the 21,s weren't far behind them in quality
if you find a 4 jaw for it, make sure it'll stand the 1200rpm ... cheaper chucks've been known to burst at speed.:oops::oops: IIRC Pratt Bernerd were the std fit. Good luck finding one :(
bit of spec for you
"Both very heavy machines, the 18" & 21" Dean Smith & Grace lathes were superbly made and capable of lasting for decades if well maintained.
Both lathes were available with a standard between-centres capacity of 48 inches with either a straight bed, or one with a gap having the capacity to take a piece of material 32 inches in diameter by 10.25 inches thick. Long-bed models were also available to special order in which the capacity rose in increments of 12 inches - to a maximum of 240 inches.
Again, as on the smaller lathes, the real swing was greater than that suggested by the model names. The "18-inch" version would turn 20" in diameter over the bed covers - whilst the "21-inch" managed to accommodate 22.5 inches.
Like other DSG lathes of the period the headstock spindle could be ordered with either plain or roller bearings. The spindle and its three bearings - the front plain one was six inches in diameter and over six inches long - were of ample proportions - and bored through to pass a 3.5-inch diameter bar.
A 12.5.5 hp 1440 rpm motor, driving through multi V-belts, gave eighteen forward and six reverse speeds, with the plain bearing model able to run from 5.3 to 420 rpm (or 7.5 to 600 rpm) and the roller bearing version (only) from 10 to 800 rpm.
When used with the three extra changewheels supplied with the lathe, the screwcutting gearbox (driving a 2-inch diameter leadscrew) was able to generate forty-nine pitches from 1 to 64 t.p.i. An extra six changewheels (supplied at extra cost) allowed inch pitches up to 8" to be cut, together with metric threads from .5 mm to 200 mm. In addition, 49 sliding feeds of 12.5 to 800 cpi and forty-one surfacing feeds of 25 to 1600 cpi. were provided by a separate power shaft, the direction of rotation of which could be reversed by a control lever mounted on the right-hand edge of the apron.
Both headstock and tailstock accepted No. 4 Morse taper centres, the former with a sleeve adaptor.
Supplied as standard with the lathe were: a coarse-pitch screwcutting arrangement, feed reverse within the apron, 4-way toolpost, catchplate, 18-inch diameter faceplate for the 18-inch model, 22-inch faceplate for the 21-inch model, fixed steady with a 7-inch diameter capacity, No. 4 Morse centres, a drill holder with a No. 4 Morse socket, suds tray, splashback and a set of spanners.
Optional equipment included a detachable-gap bed of any length (in 12-inch increments) up to 240 inches between centres, coolant, a larger 10-inch capacity fixed steady, a three-point travelling steady, larger faceplates of 30 inch diameter for the 15-inch swing lathe and 33 inch diameter for the 17-inch model, taper-turning attachment, six extra changewheels for inch and mm pitches, additional changewheels to generate metric, diametral, module, B.A. or other threads, an automatic trip mechanism for the longitudinal carriage feed, electric "quick power" traverse to the carriage, special tailstock with a built-in revolving centre, single pulley (flat belt) drive. from the motor, a micrometer carriage stop and the usual range of 3 and 4-jaw chucks, collets and steadies.
Unusual to see with a flat bed, would usually have two ridge guides, one for saddle and one for tail stock. But then being a turret it won’t have a tail stock and could be the mass produced war version for churning out parts
If you're only looking to do stuff up to that size, I wouldn't bother with an old Colchester or the likes. Whilst the construction is of course superb, they simply don't have the speed for small parts with carbide tooling. Carbide runs a lot faster than HSS and it's all carbide these days. You could of course fit a VFD, but more expense and hassle.
I have a Warco WM290 with variable speed and DRO, it was a lot of lathe for the money although prices look to have shot up- I paid £3300 with the vat two years ago, now they are £4400 o_O.
I have heard horror stories about the vari speed failing prematurely. But it's a joy to use compared to it's belt drive predecessor. I'm frequently running around 1500RPM for turning, before switching toolholders and simply backing the dial down to 300RPM to part off, and then increasing the speed with one hand whilst keeping the crossslide pressure applied as I part through. So balancing the speed with the feed rate to take account of the diminishing circumference, reducing chatter and minimising the risk of snapping a parting bit as you get towards centre by increasing speed and reducing feed. Can't do that on a gear or belt lathe.
I’m not up to date with modern small stuff, so that’s really helpful Doob. I’ll have a look at Warco. Chances are I’ll never wear one out if I buy decent. Do you use yours much?
circa 450 kgs Bri ... but TBH they're not a bad thing to hand ball / skid about .... the 20" wasn't any bigger than a 20" benchtop, just had its own stand :rolleyes: and is built properly for a long life .... many years since i've owned a Bantam, but'd have another anytime .. great little lathes and rarely done any 'heavy' work.
oops .... forgot to post this yesterday
