tree surgery training?
Possibly, ive only got a micro and i think if i wanted to do more i would need a 2.5 ton machine. I dont really have the space to store said machine plus buckets so that means renting space. Im not convinced there is enough work to pay for all that. Also the work there is would need to be done cheap ie less than £300 a day so not really worth the investment.
Working on the mainland is not feasable as its £200-£300 in summer and you loose 3 hours.
Would you not be better off with a 2 tonner with expanding tracks if you have just one machine? Way more scope for attachments/hire but will do most jobs a 3 tonner will and much of what the micro would, can always hire a micro easily enough.
£300 is not particularly tempting though I can see that but wouldn't that be reflected in the sort of rates for tree work on the island too?
Russell
Anything bigger would have to be left outside the front of the house so not ideal.
I think the problem with diggers is you can hire a 3 tonner for £77 a day, a micro for £40-£50 and delivery is £25 each way.
Also the only people with spare cash over here are old bids and they don't re-do their driveways very often or at all.
To be honest i like a change every few years anyway.
Nothing wrong with being a jack of all within a limited radius 👍🏻 forget the tickets, just stick to what you can get to with a polesaw. Hedges etc.
Maybe you can add a small mewp later. Could do all sorts with that.
Maxus
Yes I like the idea of a self propelled elite shredder, 2 wheeled self propelled stump grinder and maybe later a mewp of some sort. I think that lot would do some work.
Beast of a chipper, but let me down with some electrical issues so fixed it and got rid. I found when I was using it it was always a gruelling day, getting scratched by brambles, lugging brash around, cutting hedges all day, feeding heavey branches in ect. And unless you had a chip box on the vehicle it was messy. If I went down this route I would have a vehicle with a tipper you can chip straight into and the chipper on a low plant trailer, and a labourer.
Exactly. All small kit but lets you offer a complete service along with a micro.
The self propelled chippers look nice but big money. Whatever you get make sure it discharges via a spout rather than into the floor from the bottom.
The cheap trolley type are good enough at little money, just be sure to go for 15hp.
When I was doing tree work I had a tracked timberwolf. It was great in the sense that you could get the chipper to the brash rather than the other way round- the amount of people that didn't need much convincing that it was far easier to process the trees in situ leaving the woodchip for use in the garden, made my life easier, saved them some money, and no chip to have to dispose of. Mine was more suited to larger rural properties due to size but if I was doing alot of back garden work pruning/hedges etc id definitely be looking Into one of those small micro chippers (jo Beau?) or something similar
Maxus
Many years ago I had a gtm1200 chipper (gravity fed trolley type thing), and a ifor williams gd105 with caged sides. It worked really well, I would chip into tonne sacks, could fill up 4 tonne sacks and still have room for the chipper. I would then sell the chips for £50 a bag. The only thing with the chipper I was using is it was quite heavy and you needed a trailer with a low bed so the ramps weren't too steep, still had to take a run up!
Many years ago I had a gtm1200 chipper (gravity fed trolley type thing), and a ifor williams gd105 with caged sides. It worked really well, I would chip into tonne sacks, could fill up 4 tonne sacks and still have room for the chipper. I would then sell the chips for £50 a bag. The only thing with the chipper I was using is it was quite heavy and you needed a trailer with a low bed so the ramps weren't to steep, still had to take a run up!
£50 a bag for woodchip?! You and @DaveDCB are clearly experts in flogging crap for a very good return!!!
