tidy lil' 'Drema
same cab as mine so "A" suffix ... same age just about and a little bigger bum ... sadly no price
couple of buckets with it
"Four wheel drive
Hydrema
M 1020
Shield --
(blade)
4 cylinder Perkins engine
Engine type 1004-40 T
road and working lights
hydr axle support
80 cm mandrel Tec 2- shell grip
Rotater
Adjustable boom
central lubrication
87 hp, 3+4 control circuit
hydr ditch bucket 1,80 m wide
Type GLS 107
backhoe bucket 0,50 m wide
Central lubrication
Tires 9.00-20 approx. 10-20
Operating manual engine
Operating manual excavator
Spare parts lists
German machine "
She looks very tidy outside . Be interesting to see in the cab and what sort of hours it’s done
10,086 hrs Vin -- in the ad. .... not the fanciest of cabs inside to get ****ed up TBH ... pretty plain and can get seat squabs for them .. can't recall the name but a widely used make. pity there's no price
I wasn’t a fan of the central lube , I took it off my duck as I didn’t think it was greasing everything properly I and just used the lines to give me a central greasing point .
Some people just arn't satisfied. If it is not greasing how you would like that is due to the setup which can be altered.
I really like how it greases at different angles as it is not relient on you being able to reach or parking up the same way each time.
I had a Volvo duck with about 10,000 hours on it and central lube and no play in any pins. That clinched it for me.
Usually problems with 8t not greasing properly are the lines though rather than the unit so using them as extended lines won't necessarily sort the problem.
It did , they are still in use now . The issue was with the unit . I did try to sort it but it just wouldn’t push enough grease to the furthest points . I could of tried replacing the unit but I’m happy enough with the set up now . It takes no time with my Makita grease gun all done from one point
