Terrex hd1000 oil light on
Max in a hole
Hi all
I have a Terrex HD1000 (unsure of year) with the oil light on constantly whenever their engine is not running. Originally it wouldn’t start when I got it out on a job I managed to get it going by putting a live to the starter relay I’ve now got it home and bought a non oem anti start module to put in it which makes it start and run as it should. The non oem module doesn’t have a seat switch on it but I don’t see why this would’ve meant the oil light has come on. When I had the original anti start module installed the “O1” light was always on.
Does any one know why the oil light is always on? I tried servicing it even though it wasn’t due a service with new engine oil+filter, hydraulic oil+filter, fuel filter and air filters but it hasn’t gone off on its own. Is there a reset button?
Does any one know what the “O1” light refers to on the anti start module
I could get the “O3” light to come on and off when I moved the forward and reverse leaver so I came to the conclusion I want all lights to be off and not all the lights to be on for the anti start module.
Swap the oil pressure switch, kubota engines are known for them going dodge.
