Short auger flights, 65mm drive
William127
William127
Anyone point me in the direction of a supplier of short auger flights, 65mm round drive?
Only need to do 2ft deep holes and a 4ft auger is a bit unwieldy on the micro- turns it fine but it's bit of a pain when you only need half of it .
Cheers 👍
Cheers 👍
Micro is sub optimal for augers. Have drilled 400 mm holes with E10 but it’s a VERY different experience to using a 2.6t on same tool.
William127
William127
It's not the best but I've no complaints in the actual hole drilling department, just waving a 4ft auger around in front of a micro arm doesn't give you a lot of height to play with 👍
