Larivkitt
the price of the Rock 140£ - 250£ per m2 depends on size and where to buy all sizes are in centimeters from 30X30. 40X40. 50X50. 60x60. 100x100. the depth is usually 5 to 50% more than the height and length can vary from 50 to 200.
Norway's national stone, produced in Larvik! Used for support walls for private and public facilities. Sizes above 50cm depth are particularly affordable compared to Chinese granite. Price applies to a truck loaded in stock in Larvik. We can also help with transport if desired.
Larvikite block 100 is about 100cm high and 100cm deep. Lengths are falling from 80-150cm.
Front is split and top / bottom is with drill pipe holes, split or cut.
block is coarser than eg Chinese granite walls. Therefore, larger joints and deviations must be calculated.
Deviations in height can vary by +/- 30mm.
Deviations in depth can vary by +/- 100mm.
As a plant contractor am i getting better prices then the man in the street, so just tell me the size you want and how many length meters you want and I can get a Prize for you including Shipping til UK port.
OBS. PICTURE IS ONLY FOR ILLUSTRATION, AND DOES NOT SHOW CORRECTLY STRL
