Robin diesel engines
O
oldchips
These are two Robin DY23-2D diesel engines.
Hand start, 230cc, 4.8HP.
These are new, unused spares bought many years ago, and never used. Note the absence of a fuel tank!
I did put oil in one and run it. There is a compression release system allowing easy starting.
As used on lots of generators, concrete mixers, pressure washers etc etc, a very common engine.
Have two, price £50 each.
Located near Grantham.
Having a bit of a clear out OC :unsure: ....... what's the output shaft dim.s on these please ... looks tapered ? ... any key way or centre thread tapping ? what's the PCD or square on the mount holes and threads
O
oldchips
Output shaft is tapered, from 25mm down to 20mm over a length of 25mm with an M8 tapped hole.
Fixing centres are 65mm by 65mm with M8 tapped holes.
No circular register, just the bearing hole 42mm diameter.
miles gosling
Dont suppose these are still available are they?
I have a nearly new - 10hrs run time - Robin DY27 Diesel 5.5hp 270cc. Not quite the bargain these two were, but close in terms of value. Weirdly, I collect Robin Stationary Engines. They, the DY Series of diesel engines, are second to none. The fan cowling although looking like pressed steel, is a sandwich construction
of steel/composite material, to reduce fan noise. The fuel injection is a system made by Bosch and lasts forever...
Metalurgy is an obsession with Robin Fuji Japan and they prove how much effort they put into every single component by running a sweat-free 7-10,000 hrs in examples I used to service and repair,.Although I am a Citroen car mechanic by trade, I served my apprenticeship on Datsun. It was then I started to appreciate just how good machinery from this country can be. The only similar engines in the same class as Robin are IMHO Shindaiwa, also a Japanese company. Honda are a class below the best of these two makers. I will shut up now :)
Thank you fo accepting my membership, regards, Donald (Toby is my Cat)
Reply here if you are interested. I'm NE Lancs. I will obviously abide by forum rules re selling anything :)
great first post @toby mog :giggle:
T
toby
Thank you. My most (sad?) prized Robin in my small collection is a 26cc 2-stroke with reed valve. They gave them as a kit to high schools in Japan for students to assemble & study. Mine has unfortunately been built, but is still unrun. I believe in Germany they go for the equivalent of $900 USD in assembled forrm. The unmade kit is close to impossible to find. I wish we had them when I was at school in the early seventies. I Did get a moped engine - an NSU Quickly
50cc 2-stroke - which I sectioned to show the porting & crankshaft. The second project of mine was a pulse-jet engine. Thankfully it never started. Always fascinated by engines, nearly half a century later, I still get excited peering into any engine :)
now that takes me back to my school days/early teens ... blatting around a field behind me mates house on an old 'Quickly' ... we graduated to a 350 AJS :giggle::giggle:
I have a Robin engine on a hydraulically powered airless spray unit ... was always a good starter .. not run it in years ... ought to take the drive belt off and run it up sometime :rolleyes:
I too have a small collection of early Villiers motors and a very old J.A.P. cyclomotor, that I sectioned as a teaching aid when I taught Motor Vehicle, in secondary school, very early 80s along with DCT and eng. drg. amongst other things :rolleyes::)
T
toby
When I spent a few moths as a small engine mechanic, I was offered as many Kawasaki KT12AD engines as I could eat. They were from a local lawnmower shop and were about £40 each for a brand new 22.6cc 2-stroke of exquisite quality for what they cost. I swapped one for a J.A.P. lawnmower engine, maybe 50cc, it sat undeer my bench at work for years. It would start first time, no matter how half-hearted the pull on the rope recoil started. A little like the Victa Australian lawnmowers. Reed-valve crankcase induction, their engines would spin over seemingly dead. yet always 'catch' just as you thought it hadn't started.
Don't get me started on Cyclemotors: my dad bought us a 49cc PowerPak clip-on engine (fascinating history I will try and find the link) and boy did that engine get me into trouble. Truanting from school just to mess with it: Five Weeks and one day was the record. 'I cannot remember seeing Ian at school this term' was on my report. That comment was from my Form Teacher!
This was early 1970s and the engine was missing the carb. and with no eBay, tracking one down was close to impossible for a 12-yr old on paper-round wages. My dad bought a huge roll of fibreglass matt. Whilst rolling it up to be neater, there in the middle was the correct Amal carb for the cyclemotor engine! I have no idea just how it got there.
I never did get it to run but what fun :)
got a 320 SWM-Gori trials with a reed/disc valve Rotax in it .... can come to a virtual halt, give it a whiff and it'll pick up from nigh on dead stop ... remarkably responsive motor .. brilliant in a trials bike (y) :cool: ... keep meaning to drag it out and have a tinker sometime, but never seem to get round to it :(
T
toby
There are several Chinese clones of the DY Series of engines. A new DY27 from Subaru Robin was £2k in 2017 when they were discontinued. A Chinese 230cc copy can be had for the price of a new injection pump & injector. About £290.
A man used to ride an SWM 250 Enduro as his ride to work bike. He parked it on the street overnight. It would last around two hours nowadays. I've only ridden two peoper trials bikes. The 250 Montesa would canon fist-sized clods of earth from the rear wheel at your back if you set off in too low a gear. Amazing.
have had a couple of 250s and a 350 Monty ... not a bad weapon ... my favourite and bitterly regret ever parting with, was a Cotton with a Minarelli 220 and Del Auto square slide carb ... was a brilliant trials bike .. such a sweet, gutsy engine .. the SWM with the Rotax'll take some beating for flexibility though
and yeh .. you couldn't park that on the street these days .. be " gone in 60 seconds " :(
The good old days, we used to ride round the tennis courts at school on a Raleigh run about, and BSA bantum, in motor engineering we used to drive around the school field in an Austin 1100 or a moggy minor 😊
