T
topkit
When machines did not have air con and suspension seats.
Why is cab on wrong side? Thought the video was reversed to start with . Would keep the feet busy - stop you getting DVT in that machine !
's the way they were ... big 6354 Perky behind the cab and all the mechanical valve gear on t'other side ... had the chance to buy one once, years ago, but didn't have the use for it at the time - scrap moneyWhy is cab on wrong side? Thought the video was reversed to start with . Would keep the feet busy - stop you getting DVT in that machine !
Early Hymacs and Priestmans had cabs on the right, same as cable excavators. And the same as that machine in the James Bond film.Why is cab on wrong side? Thought the video was reversed to start with . Would keep the feet busy - stop you getting DVT in that machine !
