Quality bolts
Russell
Can anyone recommend a website that's sells good quality bolts? The last lot I bought were made of cheese, the nuts and bolts striped and we're so soft I beat the bolt back through the nut with a hammer.
Never had a problem with anything bought in the uk. Chinese items can have suspect bolts but anything from a bolt factors has been fine for me
Screwfix can be cheap (for once!) if they have the size you need.
Depends what quantity but Parker steels are good for bulk buying, say enough to hold a barn together
They are also very cheap for the epoxy resin fasteners with the glass vial
F P Hertings were always good for me .....
their delivery is awesome(y):cool:
selkent fastenings .. part of the selmach group ... Hugh Bushnell and his brother Julian ... nice guys and have bought a lot of gear off them over the years
P
Pod
Off the shelf bolts are generally 8.8 Grade Tensile strength & are general purpose-
Usually 8.8 stamped on bolt head
Used in structural steel & general Fabrication projects
Nuts must be 8.8 Grade also
.Beware of cheaper bolts that are 4.4 grade - they will shear very easily -
Threaded bar is 4.4 Grade (unless specified by supplier) & should be avoided
Higher shear values are also available for bigger loads
Headline (Nut Screws Washer and Bolts) - thread pitch unavailable!
