Powertilt hitch for Takeuchi TB216/016
Selling my tilt hitch. In very good condition, hasn’t seen much use as only use it on certain jobs, it incorporates a semi quick hitch so just one pin to change buckets which is pretty quick to do. would estimate it’s been used for about 300-400hrs from new. Price £1200
Located Dartmoor, Devon
Call Matt 07508043703.
I’d better add that clearly the digger or bucket is not included in the price- just the hitch!
bargain .... what's the max size m/c is it intended to fit ? pin sizes and centres please ?
After one for the 3t really but would be interested in it for the 1.5t although im on 25mm and I think this is 30mm
.... could do with knowing dipper width etc
Hg2702
Hg2702
I think it lines up with Takeuchi
30mm pins
105mm dipper width
130mm centres
i think
Sorry, Think hitch has sold pending payment. But yes it’s on 30mm pins. I’d have to measure dipper width next time I’m there.
Sounds like a good deal to me. How come you're selling?
It’s a good hitch when it’s on the machine- but for me it doesn’t work out. I run loads of attachments often on a days job.none of which are compatible with this hitch as the attachments are mostly welded in pins- plus have to disconnect hydraulics as only one set. I think il just get a tilting grading bucket so that it’s easy to swap around in the wedge lock. The wedge lock is too wide to hitch onto the powertilt too. I will miss the full tilt battering banks etc.
Just adapt the top of the power tilt to suit. Best of both worlds. I always use mine in stack.
