P
Pops Hall
Hi from South Wales Uk I have the 8014 putting new tracks on, doing the adjustment, the bolt has the pin through, what holds it against the cover plate, I know it’s long pin out
There is nothing else to adjust the bolt is 28 mm on this machine a good socket set is essential
raise the body off the ground with the bucket as high as practical and safe, mind your head, ouch!!
the rear drive cogs teeth are smaller so easier to prise the belt of with 2 people, insert a suitable bar in the cog slowly move the drive back and the belt should come off, putting belt back on,
we put the front teeth into the belt took the slack out of the bottom put the bar in the rear cog slowly into front drive prised the belt back on, hope that useful
