still learning
Anyone want to put value on our poclain 75 not run for 8 years only parked up for hydraulic leaks: good tight machine but rot is starting to get at it .
Got to be a bit of value as a repairable or spares for a classic. They were good machines in their day but were always leaky .Anyone want to put value on our poclain 75 not run for 8 years only parked up for hydraulic leaks: good tight machine but rot is starting to get at it .
CMn?Great machines and they had early servo controls too, Jeremy Rowland over on CMn has one that he has been restoring alongside his Hymac 580.
Classic Machinery networkCMn?
Around £110/t X weight. 75 generally will sit around 18t so around 2k.Anyone want to put value on our poclain 75 not run for 8 years only parked up for hydraulic leaks: good tight machine but rot is starting to get at it .
how bad were the leaks ? If you can get it going and it has a few buckets I’m sure someone would buy it. Where abouts in wales are you ?Anyone want to put value on our poclain 75 not run for 8 years only parked up for hydraulic leaks: good tight machine but rot is starting to get at it .
I'd say the running gear'd be the ultimate deciding factor on its worth ... no way around a bollo-ed undercarriage, other than replacementhow bad were the leaks ? If you can get it going and it has a few buckets I’m sure someone would buy it. Where abouts in wales are you ?
Also think about what you’ll take for it as no one can buy it til you say what you want .
Tbh with a larger machine over 13t it's really the weight unfortunately.I'd say the running gear'd be the ultimate deciding factor on its worth ... no way around a bollo-ed undercarriage, other than replacement![]()
Sadly you probably right . I saw a 60 locally last year generating a fair bit of interest . I doubt if it was a 75 or 90 that the interest would be the same.Tbh with a larger machine over 13t it's really the weight unfortunately.
A 20t isn't really worth breaking down for a container. And they are reasonably cheap. If it was a Kommie or Cat there's value but sadly the older euro makes (except liebherr) don't fetch great export.
