Adam
Does anyone know what material pin shims should be made from? Thanks
Thanks. I just wanted to make sure the material spec was correct. We need 650 in total from 45mm id upto 140mm id for an export customer. From 1mm to 5mm thick so want to get the material correct before getting them lazered out by a family member. We plan to "nest" them and tweak the quantities to reduce material wastage.
I was a little confused as some are sold as "hardened" and from experience some thinner shims will shatter rather then bend. But to be honest i've not paid much attention to the material used until now.
https://www.htsspares.com/catalogue/plant/excavator/breaker-pins/show/pin-shim-washers
Yes Druid, that is us @ www.plantparts4u.co.uk
There is a company in Redditch called Andrew and Elmes the phone number is 01527 522771 they manufacture pins, bushes and shims at very reasonable prices if you speak to them they will ship out whatever you want and Allelys use them all the time and so do I,
I actually owe them a couple of hundred for stuff so I'm going to see them in the morning.
