Anyone running any of the 110v 25-30kg breakers?
Any recommendations
Have hire a hilti a few times in the last month but it's getting to the point where better off paying off my own one rather than hassle of hiring and having to collect and drop it off
Was looking at used but now leaning towards new.
Is 240v still considered a no-no, I know you can run a RCD at the plug socket but is it still safe if the lead gets cut or over heats for some reason? I've got a 2.7kva 2.2kw generator that will run either 110v or 240v but with generators being floating earth so have there own circuit cut-out, as can't have a RCD fitted without changing the earthing setup. Would it be advisable to use the generator to run 240v in a construction enviroment.
I know the JCB beaver packs have more power and a better hav rating but lugging around 100kg of beaver pack is a nuisance and takes up alot more space
Any recommendations
