Mini digger best oil flow
Hello
Does anyone know which sub-3 tonne mini has the highest aux oil flow rate? The Kubota KX30-4 apparently chucks out 49.5l/min - can anything better this?
Cheers!
F
fred
i have the 030-4 and it has dedicated pump for the aux which is the main reason I bought it as it has to drive the engcon.
Mintsauce
Mintsauce
Takeuchi tb219 very respectable for its size at 40lpm.
Bobcat e26 has around 53l and also the new 27 model
Takeuchi tb30 has 54l
F
fred
This is the 5 ton auger on my kubota, its probably a little too big but we wanted it to be interchangeable on our 5 tonner as well. I steal the rotate feed from the engcon to run it which means you can bore a 45 degree hole if you need to (strainers?). Whilst it doesn't spin as rapid as the smaller model it turns just the right speed to not flick crap everywhere and the teeth chew through anything.
Can't go back to manually digging post holes now, this is just so fast and easy.
(y):cool: ..... tha's the way to plant posts for sure Fred :giggle::giggle:
