maybe a stupid question??
mart1602
is there a standard fitment on all makes for flow and return on hammer lines,icant trace the pipes back and have 2 female fittings on machine
If you press the pedal/push the button that activates the breaker you should see one of the pipes flex that will be feed the other return but on large machines they are piped the same apart from Daewoo for some reason
Rob 210
On tick over stand on the pedal (briefly) and see which pipe pressurizes.Probably the most incorrect way ,but works for me:rolleyes:,But DON'T forget to DE-PRESSURISE the system as soon as you locate the flow.
Rob 210
Thanks Mog
Just thought it was me with a bit of a cowboy approach to finding the answer to such probs:D
mart1602
thanks both,nothing wrong with that better than stripping all the panels off to trace pipes back
