Manitou telehandler hard steering. Please help
I
Islandplants
Hi Everyone.
I have recently joined the maintenance team in a plant hire company after several years working in the marine industry. Within my fleet I have 2 Manitou MT1745 telehandlers, 1 MT730 and 1 MT625, all of which are about 10 years old with between 2k and 5k engine hours.
There appears to be a common issue between the MT1745s and the MT730 in that the steering is very easy when only the the front wheels turn. This changes however, when the operator engages 4 wheel steer at which point the steering becomes almost impossible to turn at a stand still and very difficult to turn when the machine is in motion.
Is this just the way these machines are or is there something wrong ?
I would very much appreciate any input this forum may have as to what should I look at first and what are some tests I can perform to suss out what's going on ?
Many thanks
PM
I’ve just had two weeks splitting my time between operating two 1840’s, one hystat and one with a Turner 4 speed. Neither had this issue. First suggestion, have they got the right oil in the system? Should be a 46 oil. Then check the steering mode valve is shifting properly when you shift the selector lever. Seems odd that all three machines are suffering the same issue.
Hi Everyone.
Many thanks
PM
Steering priority valve id say. Should be able to strip it down and clean it up a bit
ACEngineering
ACEngineering
Hi Everyone.
Many thanks
PM
Steering priority valve failing/sticking was common on the MT models.
