P
Pete's
Can anyone tell me what make variable displacement pump was fitted in the old 1990's Liften 3/4 dumper the one with a foot pedal to control the speed & a spool block to reverse direction operated by a lever by the spool valve for tipping & lifting the skip.
My problem is I have drive as soon as I engage forward or reverse on the spool block without touching the speed pedal, the small plunger is free in the control unit held on to the pump unit by 6 of 10-24 unc allen bolts, but the large piston under the aluminium cover held on by 4 of 10-24 unc allen bolts does not move, has any one had this problem on there dumper, it has been sat for about 5 years since last started?
Or does anyone have a workshop manual they could sell me or advise where I could get one?
Many thanks, Pete.
Many thanks, Pete.
