Kubota KH-66 fuel system
Swagger
Hello all, I'm new here, please be gentle :)
Can anyone tell me whether the KH-66 (with a D1402Bh engine) has an electric fuel pump or not, and if so, where it is ? One wiring diagram shows one, but otherwise the workshop manual does not mention one, and I cannot see one anywhere. Does it just rely on gravity and the engine-mounted mechanical pump to pull fuel through from the tank ?
Also, there appears to be no stop-tap on the fuel supply, meaning that the tank has to be under half full in order to replace the fuel filter - is that correct ?
I think they had a mechanical pump originally bolted to the block below the injection pump, but later I think they may have had an electric pump down by the radiator.
