Jake83
Hello all, new member here.
I’m British but now live and work in Thailand. We have 2 machines, a 2016 Volvo 210D and a Jap import 2018 Komatsu PC15.
I recently bought the Komatsu and I noticed a small hydraulic leak. Knowing Komatsu run 46 grade (10w) oil I looked a little more into into it and realised the company I bought it from serviced it prior to sale and changed all the hydraulic fluid using standard 68 grade oil.
Now I don’t know what to do, should I change it for the correct oil which will need a flush or leave it?
Temperature wise here it’s always 30 degrees plus so this factor must be taken into consideration.
Thank you in advance
