N
Neilom
Hi all, i have several JCB beaver packs that i am going to maintain for someone, my question is on testing the pressure and flow rate on these machines. I have a webtec flow meter which also has a pressure gauge connected to it. I have connected the flow meter and gauge to the outlet of the powerpack valve block, and then connected the gun hoses to the flow meter outlet and to the return on the powerpack block. I run the machine and move the lever on the beaverpack valve block to engage the pump When i operate the gun i get a reading of 18 LPM on the flow meter and 1300 psi pressure. I would like to know if this is the correct way to test the system and are these readings correct. Any info on testing and adjusting the hydraulics on these machines would be much appreciated
