Jcb 85z-1 eco error
johntychwith
Hi how do i get this error off the screen?
Unfortunately I believe that is a generic error symbol and it could be a wide range of things causing it.
I’ve seen a lot of people say that the washer bottle pump and/or its wiring is a very common cause, but not had that issue myself, however it’s the usually the first comment on this issue so I’d start with that.
The only time I see that on my 86c is very occasionally it will come up after swapping a bucket, once on the screen it won’t change bucket again. Switching off the machine and restarting has always cleared the fault, so I’ve not looked any further into it.
Other option is to get it plugged in by a dealer if you cannot get to the bottom of it yourself?
johntychwith
The washer bottle seems to be working fine and buckets are all working. Is stuck on there full time. I did try to reset service counter but didnt work. Thank for the reply though.
You are probably a bit limited to doing basic checks now then, if you’ve investigated the commonly suggested cause. Check all fuses and any wiring you can for breaks, not an easy task!
Have you tried isolating the machine to see if it resets?
C
charlie2
i thought you could get an error code on newer jcb machines, its not a service needed soon type of warning is it.
Regy53
Regy53
I like cake
christ there is a way to do this i just cant recall il ask a friend today, it wil be back on though but its a long press of a button or two
Press hold service button? But to clear faults it may need jcb laptop?
Was never a fan of them style screens/interface as it’s so limiting as your finding out!
johntychwith
Be great to find out . It has been serviced but cannot clear service light and or the error code which hides all of the acreen as you can see. I want to alter pressures but the bloody error covers all of the screen. Any help would be appreciated. Thanks.
johntychwith
Which button is the service one ....
johntychwith
Even if i found out what bloody error it is it will be a help . Dont fancy the 400 quid call out charge off jcb 😩🙈
