A
Agrimax
Hello folks,Wonder if anybody can help? Major hydraulics problem with the above machine.
Very little power while tracking. 2 speed tracking is switching on and off as it should.
Dozer blade is slower than normal to lift and has no power pushing down. Will not lift the machine of the ground.
No downward force on boom,dipper and bucket rams,but it will lift them up and reach ok.
Slew hasn't a lot of power.
However,if the breaker pedal is depressed while operating any other function all services work as they should.Both in power and speed. Likewise if the dozer blade is lifted to the end of the ram travel and held,other functions work fine.
This one has a piston pump with two outlets and a gear pump on the end. Pumps are providing pressure and flow as per the shop manual.With a gauge on the servo pressure maintenance valve test point,again the correct pressure is maintained.Haven't went any further yet and thought it would be worth asking the experts if there are
any common known issues with these or any pointers as to how to find and fix the problem?
