T whiting
You don't even need to go I picked up a full set of 13 buckets for less than 2k and most of that was on the 4ft
do you mean they will palletise for you, or just buy on line and then collect Thomas?You don't even need to go I picked up a full set of 13 buckets for less than 2k and most of that was on the 4ft
Is it unusual to run a 750mm of a3 tonner? Thought it was the standard larger digging bucket for most modern 2.8t these days? Would not want to go back to 600mm anyway.Ahh, the 750mm digging bucket.... the secret weapon of the 8026. Then I discovered it will run one under the tilty too - watch out your boys with your 5tonners![]()
Hi, are these still available ? CheersJCB 35mm Quick Hitch and 5 buckets
Morning all, exciting week for me... therefore the following will be up for sale.
Is it if any use to anyone?
Quick Hitch is off my JCB 8026.
JCB Buckets
9” (220mm) with teeth
12” (300mm) with teeth
24” (600mm) with teeth
30” (750mm) with teeth
Grading Bucket (1200mm)
None of the above has been used for more than 10hrs light work. 3 buckets brand new! (300/600/750mm) Still strapped to delivery pallet.
Can be washed for before new owner has them.![]()
View attachment 22506View attachment 22507View attachment 22508View attachment 22509View attachment 22510View attachment 22511
