Same reason as every other British manufacturer. Run down by the unions and management weren't much better.
Muck Truck is a great bit of kit, they do the 'standard' one (which you never see), the Max (as per pic, bigger skip same chassis, good for 360kg) and the H-max, which is bigger again and hydraulic tip, but getting too expensive. The Max is well worth it's money, the flatbed attachment is great for slabs or blocks.
Explore Muck-Truck® motorised wheelbarrows and power barrows. Reliable electric solutions for moving soil, gravel, waste and more.
www.mucktruck.com
The tyre driven 4wd is so-so, it slips easily. Not tried a chain driven knock-off, but I'd imagine they might be better in the mud. If you are struggling for traction though, all you need to do is to lift the handlebars up slightly and that puts more weight on the engine driven axle. I have turf tyres for it too, which are great and leave no trace on delicate surfaces. If the going gets muddy, you really need a tracked dumper. But for carrying stone, slabs or concrete uphill on narrow paths, it's fantastic and nippy. To turn you just lift it and spin on the spot. Makes way less mess than a tracked dumper.
I have a tracked dumper too, and they often run together. Horses for courses, one is often better for the job in hand but they both save so much labour.
Oh, and yeah it's sawdust for the workshop burner.
