is this as big as it looks? !!!!
most of the ones i deal with are for bateman ground works shovelhands for there deep drainage gangs although have had a couple out with some builders merchants when they got a lot to move in there yard
I’ve not seen them used in builders merchants, ones I normally see see the type that clamp on the walls either side, and the heavy handed twats have usually knocked f****ng great chunks out if the rings 🤬
tinydigger
tinydigger
Think that is why they had them in to try and stop them damaging them but you know what the builders merchants donkeys are like they still managed to take lumps out of rings with it by knocking them together. They could be made of unobtainum and them twats would still find a way to break them lol
K
Komatsu
I just use a set of lifting pins and chains. I’ve never seen one of these contraptions for lifting them. My initial concern with using that thing would be the forces exerted on the walls, one hairline crack could quickly develop into disaster.
Seen that happen once or twice🙈, they do get used a lot for unloading the artics when they come in,( before they’ve been loaded and unloaded fo the stock yard then moved again out onto site, etc etc) saves working at height, we’ve tried them on site but you still need so send someone down to line the steps up, then there’s making sure it gets put in a safe place as not to get covered in muck etc.
can imagine the outward thrust on the pipes must be pretty serious, amplified by the mechanics of the unit and especially only in three specific points ... as said, one defect and kaboom! ... bye bye pipe / ring .. quick and easy once set up though
