Introducing
johnpbrown22
Curious if anyone can help me locate a couple things on my JCB 508-40. SLP 50840TED576898. Looking for year and factory options
Metal plate under the model number on the rear of the machine…. Will have serial number on it, fire that to local dealer. If it’s worn off it may be stamped onto the body somewhere as well.
jd6820
jd6820
I'm guessing you are based in the US, as that model number isn't a UK built machine... Put serial number into parts.jcb.com and that should give you a parts breakdown based on age and specification.
C
charlie2
mid to late 1990s i expect my boss had a different model to that but the cab etc is exactly the same jcb had a big range of options on the telehandlers ours was a farm special agri model and was a very reliable strong machine.
